Old 01-27-2006, 12:43 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
10w40 in the pan, doh
fellows -
last oil change i did a filled it back up with 10w40. what side effects should i expect to see? will it fowl anything up like my plugs, sensors or anything like that? hit me back -
dan
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 01-27-2006, 01:26 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 10w40 in the pan, doh
A engine will run ok with 10-40. And is not a life threating problem on a short time use.
But does not lubercate the tight spots as good.
It is a little heavey for newer engines. Most manf. say to use 5W30
Check your owners manual or dip stick or oil filler cap.
You could always drain it out and put back what is supposed to be in it.
MT
MT
Old 01-27-2006, 02:54 PM
yea i'm not looking to change the oil right away after i just did it the other day. just want to make sure i'm not setting myself up for some addititional wear and tear. thanks
free hypsi87!!
Dan's White Horse
Old 01-30-2006, 08:14 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Originally Posted by BigDanTheMan
fellows -
dan
nothing is going to happen
Old 02-01-2006, 12:41 PM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
yea you will be just fine... you would be surprised what most shops do.. the few i use to work at only carried one kind of oil in there tank which was 10 30... then they would just right like 5w30 and so on, on the sticker
