Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-27-2006, 11:30 AM
acolvard acolvard is offline
2002 GT 5-speed clutch slipping?
My 65,000 mile GT feels like the clutch is slipping when shifting with a lot of power. It feels like it is somewhat slow to fully engage. This doesn't happen all the time, but mostly happens when I am hard on the gas accelerating even when the clutch pedal is all the way released. After what feels like a small amount of slip it engages fully and the feeling goes away. I believe the clutch needs to be replaced, or is it something else? Also I have had a click in the front end sine the car was almost new. I took it to the shop under warrently and the replaced/check the front suspension and the problem never really went away other than for a short period. The click is more like something falling into place and metal to metal. It goes click or click - click, not click, click,click ..... Could this problem have been related?
Old 01-27-2006, 12:39 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: 2002 GT 5-speed clutch slipping?
the clicking could be a motor mount.
it does sound like your clutch is slipping. when you accelerate and switch gears, does it take a second or two for the gear to like "kick in"?
Old 01-27-2006, 03:22 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
yeah, that would be the symptoms of a slipping clutch
does the clicking go away when the clutch is engaged?
Don't act like you don't love it.
503/2000
Old 01-27-2006, 04:32 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
The clicking could be TOB rattle or lifters. I know the DSM's have a lifter problem that make them click.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-27-2006, 08:32 PM
808drifter 808drifter is offline
Old 01-28-2006, 07:39 PM
cficare68's Avatar
cficare68 cficare68 is offline
Yeap your clutch is going bye bye. If it makes you feel better so is mine and mine is a year older than yours and has 25,000 miles more than mine
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 01-28-2006, 07:47 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
nothin
Old 01-28-2006, 10:45 PM
The clicking occurs around the shift clutch in and clutch out. I would imangine it is related to the clutch. I am going to call Mitsu and see if the help on the labor due to the fact that the problem was found, but not solved under warranty. It is worth a try. But, if they are going to do it I want them to install an ACT 2600. I plan to go SDS soon so I was going to replace the clutch anyway. I want to make sure everything is perfect before the BOOST comes. I am also replacing the brake with Powerslot. Should I go big or standard size?
Old 01-29-2006, 12:03 AM
yep sound like the TOB
Old 01-29-2006, 12:09 PM
Sleepr awd's Avatar
mine got the rattle the first day i got the new clutch put in, and it was on the old one too, i think i'll try upgrading to an ACT
and teh dealership will do nothing about TOB rattle, at least nothing permanent, so your best bet is to get a nicer aftermarket clutch that is immune, like centerforce and ACT i believe have good non TOB rattle clutches
i dont' think they make a 2600 for our cars though, its just the ACT heavy duty or something weird like that....
as for brakes, i'd like to get ahold of some evo8 brakes for myself, the fed-spec swap is also an upgrade. it just depends on what you feel like, there is nothing that says bigger isn't better with brakes, as long as you can handle them, and if you are boosted, all the more reason to get them
503/2000
Old 01-29-2006, 04:37 PM
rodbls's Avatar
Bigger brakes will only make a difference if there is a lot of rubber up front. Make sure you get some big ass tires to hug the road (not only for stopping but also for the go boogy).
Old 01-29-2006, 05:46 PM
evil6remlin evil6remlin is offline
The brembos look awesome too along with the added stopping benefits. Make sure you get some wheels with the correct offset that will clear them instead of getting spacers and longer studs for the stock wheels (makes me feel safer).
Old 01-29-2006, 08:39 PM
any one else not have ABS on there eclipse?
Old 01-29-2006, 10:00 PM
only the GTS came with ABS, i believe
Old 01-29-2006, 11:05 PM
rodbls's Avatar
No...my 2000 GT has ABS, they might have changed it, but I am pretty sure it was standard on mine.
