Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-27-2006, 10:56 AM
Skengdon7 Skengdon7 is offline
Gas tank capacity
The specs for the '00 eclipse is 62 liters which is about 16 gallons. My 2.4 eclipse takes 13 gallons max...
Old 01-27-2006, 12:37 PM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
Re: Gas tank capacity
16 gallons is the capacity. the most i've ever put in was like 14.2 gallons
Old 01-27-2006, 02:30 PM
OK. Normally, I drive my way after when the gas light comes on...a bit risky but I figure it runs on fumes (I always fill the tank and then drive 'til the gas is done). When I refill, the nozzle goes on auto until it reaches 13.2 gallons. Even when I continue to manually pump gas it barely takes anymore...nowhere near 14.2...and I'm fearful of it overfilling....
Guess I'll continue to pump and see what happens...can I cause any damage???
Old 01-27-2006, 02:47 PM
i normally overfill mine. i've driven so far that the needle was on the bottom right edge of the "E".
Old 01-27-2006, 03:26 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
i've done 13.9 gallons max and the needle was bottomed out i think, a good 1/2" under the final line
feasibly you could go another few gallons after the light comes on, but i usually just push it to 300-330 miles or so, somewhat aggressively
Don't act like you don't love it.
503/2000
Old 01-27-2006, 04:30 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
On my trip to California last spring my buddy and I drove with the gas light on for like 130 miles (we were doing about 90mph). When we filled up we put in about 15.8 gallons. That was risky...but it still had a drop or 2 left. The most in town I have put in is like 14.6. I dont think our tanks are designed well because there seams to be a lot of gas it cant get too if our cars say they need gas when there is like 3.5 gallons left. Maybe the factory just set the warning light a little cautious.
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-27-2006, 08:34 PM
808drifter 808drifter is offline
ive actually drive about another 40/50 miles on the e with the light on (stupid fuking elctric gauge) its just a saftey. i actually got 16.2 i geuss its the line going to the tank.
