Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 01-27-2006, 08:25 AM
dmanzzz dmanzzz is offline
87 b2000 over heating problem
i have a overheating problem on a 87 b2000 motor, just replaced the head and got all running great, but then started overheating...any ideas
Old 01-27-2006, 03:07 PM
mazb26i mazb26i is offline
Re: 87 b2000 over heating problem
Did you replace the thermostat? Was there any stop leak in the cooling system before you replaced the head? If so, you're radiator may be plugged. Is the fan pulling air through the radiator good? Maybe there is debris built up on the front of the radiator. Since you just replaced the head, are you sure the head gasket sealed? Do a radiator pressure test to see if it holds pressure without the engine running. Also check the radiator cap to see if it is still holding pressure to whatever the rating is on it.
Old 01-27-2006, 03:23 PM
New Rad Cap, New Thermastat, Radiator Is Flowing Good, Didn't Run A Presure Check, Will Do That...no Stop Leak...all New Hoses...got Me, Unless The Head Cracked...
Old 05-21-2006, 11:38 PM
zoom zoom zoom zoom zoom zoom is offline
unless it has been replaced on that model with a timing belt the water pump is probably bad mine acted crazy different temps all the time then the water pump fell apart
Old 06-29-2006, 07:51 PM
cleantimestream cleantimestream is offline
Another possibility ,,,,,,,, sigh happened to me with an 87 celica ,,,,,,, they shaved the heads down to far thereby creating more heat that cannot be carried away by mere water ........... take thermostat out and see if runs hot at idle {worst case scenario},,,,,,,,,,, You already made mention water is flowing across radiator,
Old 07-01-2006, 11:23 PM
Kyrasis6's Avatar
Kyrasis6 Kyrasis6 is offline
Send a message via AIM to Kyrasis6
Is the air vent on the thermostat at the 12 O'clock position? What percentage of water to anti-freeze are you running? Have you checked ignition timing? Taken the fan shroud off and blasted through the back of the radiator with a hose to get all the bugs out of the front? Have water leaking out any of the core plugs or comming out of the recovery bottle?
Where is your temp running on the gauge? About 1/4"-1/2" is normal, most trucks run closer to half.
Owner of Mazdatruckin.com
Old 07-10-2011, 12:32 AM
BillyDCJ BillyDCJ is offline
My little mazda overheated with a new radiator, waterpump, thermostat, then I flushed the whole system over and over again without the thermostat installed after a while, and all kinda stuff coming out of the motor you couldnt beg it to run hot. i did use 1 bottle of zerex system flush.
