8 Light mod
from 03-06 guys just did and eight light mod on my truck low,high,daytime and fog looks bad ass will try to have pic later. My daytime are amber looks like an ufo
![]() Cranked Bars Silverstar headlight + 8 Light Mod TrueFlow Intake + Airaid TBS 5% Window Tint + 30% On Front Windshield Billet Grill + Bugshield + Ventvisors And Still Spending |
Re: 8 Light mod
Where'd u get info on that?
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
Re: 8 Light mod
from the this forum but i took further they said to hook a diode from pin 85 on the relay of the hi beam to pin 85 on the low beam so i did that then i saw that they had a pin 85 on the fog light and on the drl relay so i had 2 more diode and hook them all up to pin 85 on the hi beam relay and it work HOLD ON yep it work my truck is not on fire yet. I will try to dray out a schematic at work to put on here
Re:got pics of 8 Light mod
Re: 8 Light mod
[quote]
[quote][this is how wired the relay up to make the mod
Re: 8 Light mod
thats nice man but it only looks like that if the high beams are on???
Simon R 2001 Silverado W/T 4.3 124,000 |
Re: 8 Light mod
When I turn on the highe beams the High beams, Low Beams, drl, and fog light are all on. The high beam drowns out the low beam a little I will try to get a night pic of it
Re: 8 Light mod
Did you ever get a chance to draw out the mod or can you give me a wire plot to do the mod?
What light # did you use in the DRL for amber? Thanks in advance.
2003 Chevy Silverado ![]() 2004 Bonneville GXP ![]() http://members.cardomain.com/chuckwi11 |
Re: 8 Light mod
ok away we go If you remove the cover from the fuse box on the driver side under the hood you will see the hi beam relay on your left when you remove it you will see the # 85 on the under side of the relay and on the wire diagram under the cover remember that # 85 you will use it the whole time on all the relay. now right in front of you is the low beam and right above that is the drl relay if you look they all have a # 85 in the bottem right hand corner the only one that is differnt is the fog light relay the #85 is at the top
1) pull the low beam relay and soilder a N0001 diode(radioshack 2 for .59 you will need three)with the band going away from the relay { make sure you soilder it next to the relay so it plugs back in} 2) now do the same for drl and the fog lights. make sure you heat shrink for protection. with all the diode installed run a wire from all three diode then twist together then soilder in one wire that will be soilder on to the hi beam #85 you have to use one wire because all three are to thick to soilder on the high beam. Also i use 22 gauge wire an it worked fine If you need any help I check this site alot so just give a reply
Re: 8 Light mod
the amber lights for the drls is a 3157NA or 3157N
Re: 8 Light mod
06Z71 I was wondering if you could help me out. I want to do the 8 light mod on my 99 but when i pulled off the fuse cover under the hood there is only one relay for headlamps. I found the relays for the fog and drls. Any suggestions? anybody?
Re: 8 Light mod
Don't think you can do the 8 light mode on the 99-02 due to the way it is wired because I THINK the 99-02 uses the ground and 03-06 uses 12 volt but u can do the 4 light mod the have a forum about it use the search button but my frien has a 99 I will try to wire it for 8 light mod because he wants it when he saw mine and I will let you know what i find out
Re: 8 Light mod
Yes you can do the 8 light mod on a 99-02......you can also do it on a 03-04 as well.......search under my name, 'silveradoking', or look under, 'hi,low,drl,fog'........I made a post a while back, you know back in the day,......but beware it is quite a lenthgy procedure......
2001 Chevy ' Black Beauty' Silvy, Extended 5.3 V8 Mods include: K&N Air Intake, B&M Trans Cooler & Pan, Corvette Servo, Jesse Performace Whoop Ass Tune, Whelen Strobes, Blue/Red Police Lights, Mag Lite mod, Catch Can Mod, Hi-Low-Drl-Fog Light Mod, 4 Brake Light Mod, Power Outlet Bed Mod, Royal Purplerized, Outdoors Accessorized (I'm a outdoor freak) like to take my truck where no other truck has gone (often with consequences) And soon to be: 285 75 16 BFG All Terrain tires with 3" Lift.... |
