Old 01-26-2006, 09:08 PM
208firefighter 208firefighter is offline
anyone mechanically inclined, PLEASE HELP!
I have already asked this question, but no one seems to know. I have a 2000 Z24 with a spun bearing, so I need to replace the engine. My friend has a 98 Z24 that is wrote off, so he said that I can have his 2.4 "quad 4" that is in his car. his motor says "quad 4" on the top of it, and my motor just says "2.4" on it. They essentially look the same (engine mounts in same place), but I don't know if it will fit into my car AND work. Does anyone on here know if the 98 2.4 will fit into a 2000 with a 2.4?
Old 01-26-2006, 11:22 PM
CavLCD128 CavLCD128 is offline
Send a message via AIM to CavLCD128
Re: anyone mechanically inclined, PLEASE HELP!
should...but than again im not a machanic....figure this, if it comes from a cavalier only 2 years older and pretty much the same engine look and all....if it all hooks up in the same place its gotta use the parts that are hooked up 2 it rite? good luck, let me know how it works out for u
ThE neW wHiP:
Old 01-26-2006, 11:54 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
the only cavalier that should ever say "Quad 4" is a 95, not a 1998. If the car is a 98, then the only difference is the EGR which your 2000 doesn't have. But it should work all the same.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 01-27-2006, 07:39 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
cavlcd
who do you have quoted in your sig?
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 01-27-2006, 08:44 AM
Originally Posted by jakegday
cavlcd
He's quoting the Simpsons, in a conversation between Homer and Apu.
Old 01-27-2006, 11:21 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Someone prolly switched IDI covers on it. But yes you can swap everything out but you'll need everything EM wise, and you may have some troubles going from an OBD I to an OBD II emission controll depending on your state. You'll have an engine with OBD I on a car that should be OBD II. Here in NY they are VERY strict. 96 and newer cars have our balls in a vice especially with modifications.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 02-06-2006, 11:36 PM
spanky9929 spanky9929 is offline
Send a message via AIM to spanky9929
i would fix the spun bearing and replace it with new parts you don't know how long the other engine will last i always say rebuild than replace if you rebuild you know its new and will last when you replace you may run in to more problems down the line and then spend more time and money
Old 02-09-2006, 11:48 PM
vintweed vintweed is offline
Send a message via MSN to vintweed
If you mean that the codes aren't OBD II for the 2.3 Quad 4. They are. Got the same engine, and for some good reason Gm started early in 95 If this isn't what you meant, don't yell at me please. Guess I'm just a tard
