Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-26-2006, 07:27 PM
william64744 william64744 is offline
brakes wont work
i replaced the master cylinder because there was no brakes nothing no leaks just pedal went to the floor still stoped but not very well. after i replace ythe master cylinder i can not get it to build up pressure the master cylinder is working put the pedal still goes all the way down no air in the lines i bled all the wheels there not anymore
air it has hydroassist is there a special way you have got to bleed this type of sytem thanks
Old 01-27-2006, 01:04 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: brakes wont work
Did you bench bleed the master cylinder after you installed it but before you connected the brake lines?
Old 01-27-2006, 01:19 AM
yes thin i also bled the brake lines at all 4 wheels
Old 01-27-2006, 02:40 AM
UnexplodedCow UnexplodedCow is offline
Send a message via Yahoo to UnexplodedCow
sounds like you have a leaky brake line.....check around the car. I had a wagon version do that to me once....at least it was in my yard.
Old 01-27-2006, 09:51 AM
I checked for leaks with all the wheels off nothing its not using any fluid
Old 01-27-2006, 10:35 AM
silicon212's Avatar
Confoundingly Lucid
There should be a pushrod in the power booster that makes contact with the pistons on the master cylinder. Did you check to see if that's there? It will have a ball or rounded tip.
Old 01-27-2006, 11:15 AM
yes and it moves like it should
Old 01-27-2006, 11:40 PM
Did your lines bleed well? Were they plugged, maybe? Just some thoughts. Another idea is that you have a defective master...see if you can get another in return....maybe it'll work.
Old 02-03-2006, 08:46 PM
BZR77CHEVY BZR77CHEVY is offline
I had this type of problem a few years back on an 80 4dr. For 2 weeks I played around with lines then calipers and wheel cylinders, the metering valve, and Booster only to figure out that the rebuilt master cylinder that was less than 3 months old was bad. I took the one off of the 77 caprice that was waiting for an engine transplant... problem solved.
Old 02-04-2006, 01:07 AM
i drained all the fluid out and then filled the resevor and pumped all the fluid out until it came out perfectly clean then pu it back together it works know
