Old 06-18-2002, 12:00 PM
djmr2's Avatar
djmr2 djmr2 is offline
Autmotive paint! how to do it?
Hey guys
i was thinking of using Auto paints since it seems to be more efficient route for my models, primer is cheaper and the paints are cheap too..
I was just gonna use those touch up paints that come in spray bottles.
Now, is it harder working with auto paints? are they too thick to be used?
what should i look for?
i was just gonna use the same procedures as painting with the tamiya synthetic lacqueres. Thanks
Old 06-18-2002, 12:12 PM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
I believe, and correct me if I'm wrong guys, but the paint used on real autos is a little too heavy and from experience, warps the plastic of the kit. I wouldn't be too curious to find out though.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
Old 06-18-2002, 12:26 PM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
it shouldnt warp the plastic if you put a health layer of primer on it. Check out the faq... im pretty sure that its all covered there. I've used automotive paint on a few of my models. i like them since there are so many choices. i've heard of people using factory paint even. they work just as well as tamiya paints IMO. just make sure you prime first and you'll be fine with them.
Old 06-18-2002, 04:53 PM
astroracer's Avatar
astroracer astroracer is offline
PlastiCoat and Duplicolor both have a grey sandable primer that covers very well and will protect the plastic from the hotter laquer paints. Warm all of your paint up in hot water (just float the can in the sink) before you spray and don't use the "middle" of the spray pattern to cover the model. Use the outer edges and keep the nozzle 8 to 10 inches from the subject. I also spray the paint directly from the can into my airbrush jar. it works great and like was stated above the paint is pretty cheap for the amount you get.
Mark
Old 06-18-2002, 05:18 PM
djmr2's Avatar
well
i picked up some cheap primer, looks like the cheapest one at a local store. It's the only one that says Formulated for Plastics so i hope it won't eat up the model!
Old 06-18-2002, 06:54 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
It isn't so much the primer attacking the plastic as the lacquer automotive paint attacking the plastic through the primer,the primer needs to form a barrier between the plastic and the lacquer !
:bandit: Mike
Old age and treachery will overcome youthful exuberance everytime !!
Old 06-18-2002, 09:26 PM
patate's Avatar
patate patate is offline
the best for me is to put a layer of testor primer let it dry after I put a layer of NU-HUE gray sandable primer and finally the paint
it work for me it's suppose for you too
mario
Old 06-18-2002, 10:23 PM
djmr2's Avatar
:bandit: Mike
oh ok..
so what do u propose i do to fix this? don't want to put too thick coat of primer. or buy better primer?
or start with small mist coats of the auto spray, then build up??
Old 06-18-2002, 10:39 PM
patate's Avatar
patate: the best for me is to put a layer of testor primer let it dry after I put a layer of NU-HUE gray sandable primer and finally the paint
one coat of testor 1or 2 of nu-hue and 2 or 3 of color you have a very good looking paint job and tou dont lost your body lines
mario
Old 06-19-2002, 06:45 PM
modelfan1's Avatar
the best advice I can give is spray a scrap piece of sprue with the paint and see what happens . Always wear a protective mask when spraying ,your lungs will appreciate it !
:bandit: Mike
Old 06-19-2002, 09:36 PM
djmr2's Avatar
:bandit: Mike
Thanks!
i finally came up with that idea (well similar) after remember i have the Revell Integra Type R Kit....
i just primed the extra bumper, and spoilers so i guess i'll try and paint it in a day or so!
boy does that primer dry fast, spray and 10minutes and its like dry to the touch.
