Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 01-26-2006, 04:11 PM
unforgiving_86 unforgiving_86 is offline
Send a message via Yahoo to unforgiving_86
Unhappy Honda Prelude idle problem?
The car starts up find and idles fine when ur stopped but when ur driving and u put it in nutrel it goes up to 3000 rpm's tile u stop.????? and also when i stop its like my fans keep running alittle big longer.. and makes a weird noise when it is stoped and ideling after i drove it.. fine to i drive in its a 2.2 motor i was told it was the idle sensor? if u think so where is it located on the car?
please email me ur reponses thanxs.
Old 01-28-2006, 01:51 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Honda Prelude idle problem?
do a search.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-28-2006, 08:39 PM
bobosimon55 bobosimon55 is offline
check your throttle body i had prelude and before i sold it i fixed that issue. the tps can be tha problem. they say you shouldn't adjust it though but you can. adjusting the tps which is the throttle postion sensor should be a last resort. first you should see if the the throttle plate closes all the way which it didn't on my car and it let air seep through causing the car not to idle correctly or idle down when coming to stop.
