Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 01-26-2006, 04:15 PM
OttoP OttoP is offline
460 timing
I have a 78 RV based on ford truck chassis with a stock 460 engine-4barrel carb. Anyone know what the initial timing should be set at?
Old 01-29-2006, 11:50 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: 460 timing
My manuals show initial timing (as measured with the vacuum advance disconnected at the distrubutor) of 16 deg. BTDC.
These is a note that engines made after July 15, 1977 get 10 deg. I suspect this is emissions-related. Using 16 degrees will get you a bit more power and fuel economy so long as it does not ping.
IMO try 16 degrees and back it off a degree or two if you hear any knock or ping.
Old 01-30-2006, 01:41 PM
Re: 460 timing
Thanks!!!
