Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 01-26-2006, 03:02 PM
ctuagent117 ctuagent117 is offline
idle problem
i went to the mechanic, he installed two chips into my ecu, they both did not work as they were the wrong chips. so we install the stocl chip back in. now my idle is real high at 1100 rpms, and sometimes it dips down real low, almost turns off, than shoots back up to 1100. i unplugged the negative terminal from the battery for 20 mins to reset ecu, but i still have the cel and the rough idle. also i dont know if this is connected, but my ac won't blow cold air. the fan turns on, but there is no cold air. replys are appreciated
thanks
Old 01-28-2006, 11:37 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: idle problem
what kind of car, engine?
sounds like the ecm is shot
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 01-28-2006, 04:06 PM
Re: idle problem
1997 jetta. 79k miles. what makes you think the ecu is shot? the car runs flawlessly except the idle, and i heard that it will smoothen out. my ac has me stumped. im taking it back to the idiot mechanic on wedneday. 2 liter engine
Old 01-29-2006, 03:04 PM
Re: idle problem
help!
Old 01-30-2006, 05:56 PM
Re: idle problem
any advice?
Old 01-31-2006, 10:01 AM
CaseyVR6 CaseyVR6 is offline
Re: idle problem
apparently not. and making posts in your own thread to get attention is a bit lame
Old 01-31-2006, 03:25 PM
Re: idle problem
i got these codes from autozone. can anyone shed somelight on them?
whats your problem casey? im just trying to solve my problem isnt that what forums are for?
p1452
maufacurer contrl
auxillary emmission
controls
p1420
manufacurer contrl
auxilary emission
controls
p0303
cylunder 3
misfire detected
p1580
manf cntrl veh. spd.
idle speed control
auxillary inputs.
Old 01-31-2006, 08:01 PM
VDUBMAN
Re: idle problem
looks like the guy put in the wrong chip. do you have a california emissions vehicle?
Old 01-31-2006, 10:09 PM
Re: idle problem
no it is the correct chip, i just went out and checked. no sir, i do not have a california emissions model.
the misfire was from when the wrong chip was put in, theres no misfire now. What is auxillary emission?
Old 02-02-2006, 06:58 PM
VDUBMAN
Re: idle problem
the 1420 and 1450 are secondary air stuff, check the fuse for it next to the coolant resivour and next to the battery ( on a clear plastic case thing)
Old 02-02-2006, 10:29 PM
Re: idle problem
can you be a little more specific please? i know of one fuse in the clear plastic box, its one fuse, but there are two slots, only one of them has a fuse in it. there has always been one fuse there since i brought the car.I don't see a fuse next to the coolant reservoir, but it is midnight here, and i will take a better look tomorrow morning. if i can, what i will do is take some pictures, and you can tell me if im looking in the right direction. Thanks veeD, your help is appreciated
Old 02-03-2006, 04:15 PM
Re: idle problem
ok, i understand what you meant now. the fuse is good.
Old 02-03-2006, 07:59 PM
VDUBMAN
Re: idle problem
if you have a vacuum pump, pull the vacuum line off the secondayr air combi valve (on exhaust looks like a circle thing with large plastic pipe coming off) check if it holds vacuum ( it should)
i dont even know if a 97 has secondary air.. maybe the guy that put the chip in got one for a vehicle with secondary air and your car doesnt have it, vice versa. secondary air pump and system only operates on cold startups (may explain why runs rough till its warmed up
Old 02-05-2006, 09:45 AM
Re: idle problem
It idles rough when its warmed up AND when its cold. i dont think i have the secondary air pump, but do you know how many miles it takes till the ecu relearns itself? the mechanic did something when he installed the chip though, he cut off the engine from the engine bay, maybe when he was doing that he unplugged something? I read somewhere that if something happens to the ecu, the computer will shut off the AC fan clutch as a fail safe, and elevate the idle to the factory mandated 1100. this sounds alot like my problem, do you think this is what could be happening?
Old 02-05-2006, 09:05 PM
Re: idle problem
also, do you know the fuse for the AC? that would be of great help
