Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-26-2006, 02:44 PM
pickett67 pickett67 is offline
1993 bonneville doors and other
i have a 1993 bonne sse, i purchased it used. the power door lock buttons have never worked but i can lock all the doors at once by the key from the outside...i figured it was a relay under the pass dash but i dont know which one controls the doors.?? if someone could tell me what each fuse and relay goes to under the pass dash you would be a greatly appreicated.. also the car came with a factory alarm and keyless entry but no keyfab... anyone know where i can order one for a good price....and water is leaking through the driverside firewall towards the door..and if that wasnt enough the driver rear door is stuck shut but all linkages look to be in good condish and moving freely...when compared to the working door there is a white plastic peice that moves up and down...its busted and i need a new locking mechanism i think but cant get the door open to remove it....anyone know how to get the door open if you cant operate the latch inside the lock??
Old 01-27-2006, 06:34 AM
jdq jdq is offline
Re: 1993 bonneville doors and other
Mine is a 90 sse ,under passenger kick panel there is a black box beside relays that says " potter brumfield" this I am told is for power locks and there is 2.Also it should say on top of kick panel what relay is what,atleast mine does.For your door you will have to take door skin off enough to stick your hand in and play with door latch ,doorskin should pop off.
2000 bonn ssei 155000 klm
1997 dodge caravan 92000 klm
Old 01-28-2006, 01:07 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Check E-bay for your transmitter. The OEM number you are looking for is 25602667. It is a 3-button transmitter, with the lock and unlock buttons on top, and the trunk button underneath in the center. Your transmitter is rectangular in shape with retangular shaped buttons. The newer teardrop shaped remotes with the round buttons will not work on your car. I just tried it, if you go to e-bay and type in the above part number in the search for bar, there's a bunch on there for around $20 "buy it now".
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
