1991 Chevy S-10 Blazer 4.3L 4x4 4Dr
For over a year now, the steering has had way too much play. You constantly have to correct the wheel while driving, otherwise you are all over the road. There is atleast 4" of free play in the steering wheel before the truck actually responds. I am not sure if it is the steering gear that is worn, or the pitman or idler arms. All four ball joints and tie rods are new. When the roads are icy and you happen to overcorrect the wheel, you do a cookie... i love doing cookies... just when I mean to. I need to get this fixed soon, I just could use a few ideas as to what it could be. Thanks to all! |
Re: Excessive Play In Steering!
You are in luck. Check this link out. It was done by another member on the forum.
http://www.automotiveforums.com/vbul...d.php?t=510607 |
Well, I started out replacing my pitman and idler arm and still had play, then replaced all the tie rod ends and ball joints. It's much better. Now I need to find some time to do all the bushings, they are really worn out.
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Nice modification, but first check the play in the gear box itself which is also common, many times this can be eliminated by adjusting the pitman shaft end play.
could someone give a list of items to check if u have excesive steering play?
2000 Chevy Blazer ZR2 Performance Mods: Numerous Suspension Mods: Some, but not enough Exterior Mods: Just Right 1987 Buick Turbo T Dark Red Low 11 sec sleeper ![]() .030 4.1 block, PT6262E, & other odds and ends.... My Cardomain |
Idler arm, tie rods, center steering link, pitman arm, steering gear box, lower steering shaft rag joints.
My brother adjusted the steering box but there is still way too much play. I think a new box would do the trick but a new one runs $162 with a $125 core from Advance Auto Parts. I am not sure what one goes for at a salvage yard. There is also the chance of getting one with the same problem.
