Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 01-26-2006, 10:26 AM
mrjoshuabenson mrjoshuabenson is offline
Starter???
I have a 93 coupe that I just purchased.....the only way I can start the car is by pumping the gas pedal when im turning it over and after it starts I get a very heavy gas odor. Does anyone have any idea as to why this is happening? I thought to start out with new plugs and wires,maybe even a battery just to rule those things out??
Old 01-26-2006, 10:46 AM
HAWG HAWG is offline
Re: Starter???
I would check the fuel pressure regulator, to see if I am losing fuel pressure, or the fuel pump itself. Should not have to pump the accelerator on an injected car.
Old 01-26-2006, 03:14 PM
Re: Starter???
see thats what I thought too....but the thing absolutly wont turn over unless I pump the pedal
Old 01-26-2006, 03:39 PM
DFBonnett DFBonnett is offline
Re: Starter???
When you say "turn over" do you mean it won't crank at all or that it will crank but not fire up?
Old 01-27-2006, 11:26 AM
Re: Starter???
it will crank but not fire. I talk to a mechanic last night and he thinks its the feul pressure regulator because of the gas odor i get after it starts
Old 01-27-2006, 12:36 PM
Re: Starter???
That could very well be, based upon your description.
