Old 01-26-2006, 02:22 AM
MaXXuS's Avatar
MaXXuS MaXXuS is offline
D16A1 Head On2 1.6L ZC?
Can I put the DOHC head on the 1.6L SOHC ZC wihtout any kind of major switches aside from timing belt? Or what will I need to make it work right? I was thinking about doing this with the Si Tranny I have & organik clutch.
Old 01-26-2006, 07:55 AM
Civic Jim's Avatar
Civic Jim Civic Jim is offline
Send a message via AIM to Civic Jim Send a message via MSN to Civic Jim
Re: D16A1 Head On2 1.6L ZC?
im sure you cannot do it with MAJOR work, but someone else will know for sure mate
Jim - Your Resident EDM Biatch
B16A1 I/H/E
4TH GEN UK SITE
Honda Civic EE9 1.6-i VT
Old 01-26-2006, 09:33 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Search it on the forum here. Its been talked about many times.
Old 01-26-2006, 06:10 PM
MaXXuS's Avatar
Yeah I got tired of looking through all the BS threads thats why I posted this. If someone could at least point me in the right direction that would be nice.
Old 01-27-2006, 04:52 PM
Hybrid1990crx's Avatar
go on dseries.org and do a serach theres lots of info.
Old 01-30-2006, 04:59 PM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
The head bolt hole closest to the distributor is about 1/4" out of alignment. This is the biggest issue with this swap, unless you don't mind not having your cylinder head completely torqued down! The next issue is the timing belt idler location, and you'll be spending hours at the autoparts store counting timing belt teeth trying to find the correct length timing belt.
If you're using an '88-'89 D16A1 head, you'll need to swap the D16A1 20 tooth crankshaft timing belt gear onto your motor to match the 40 tooth cam gears, or swap 34 tooth cam gears to match your 17 tooth crank gear. Then you'll also need to modify your header to match the ports on the DOHC head since the ports are about 3-5mm off.
Also, You'll be stuck with the stock intake manifold since there are no aftermarket IM's available for the DOHC ZC or D16A1, and the DOHC IM bolt pattern is different than the SOHC pattern.
IMHO, it's not worth the effort. Either swap a whole Civic DOHC ZC motor (Integra DOHC motor won't bolt in without some mods), or slap a Y8 or Z6 head on your motor.
Old 01-31-2006, 08:38 PM
MaXXuS's Avatar
Thanks for your help, I think I am gonna stick w/my original plan. SOHC ZC Turbo w/Si Tranny.
