Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-25-2006, 10:37 PM
wuckywuk wuckywuk is offline
Exclamation please help transmission problem
i have a 1993 cutlass ciera s and the trasmission does not change if i go slow. but if nail it to the floor and take off it changes all gears with a little slippage and a little vibration. it is an automatic transmission. i changed filter and put in new fluid already. before changing fluid and filter it would not change at anytime. any suggestions would be appreciated. thank you in advance for your help
Old 01-25-2006, 11:49 PM
andercee andercee is offline
Re: please help transmission problem
my car wouldn't go into third no matter what i did.. i put some Lucas transmission treatment in it.. i drove 20 miles.. then let it sit for a day.... and that fixed it...
i would try this first and if you're lucky it will work
Old 01-26-2006, 10:46 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Your problem relates to the vacuum modulator on the top of the transmission. It is easy to change and relatively inexpensive. Only takes a couple of hand tools and a magnet to change it out. Good Luck!
Old 01-30-2006, 08:48 PM
Thanks guys for your help. i use the lucas and replaced the modulator and it did not help. again thanks anyway
