Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2006, 10:50 PM
space-monkey2 space-monkey2 is offline
Banned
Angry SParkin Problems
Soo im about to sell my eclipse. (95 n/t 5speed) And i took off my header to have a buddy of mine powder coat it at his shop. And a friend of mine says lets de grease upder your hood and wash it down. So im like why not. And we did that WITHOUT the header on. And i think i got water in my exhaust ports and the valves might or droped it into my pistons. So i take out the plugs (since it wont start at this point) and check them and they are drenched. Then I buy new plugs let the car sit over night plugless os it can dry. and Then try the new ones, nothing still drenched. Some rubber tube, a seringe, and a shop vac later i think i get all the liquid out that now could consist of water/degreaser/ether/gas. Then i throw in the new plugs and and try and nothing, but the plugs come out clean. Then i keep the plugs connected but lay them on my engine and see that only the outside 2 are even throwing a spark. I had my coil checked at autozone 1 store said the primary might be bad, but the secondary is fine, and the other store said it was all in range. So the question of the day is.... what would make just the outside 2 plugs (number 1, and 4) spark but not 2 and 3? Should I be looking into a new coil? computer? wires? what would cause this?? throw me a hint.
Old 01-25-2006, 10:59 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: SParkin Problems
First off, why the hell did you wash your hood without something over the exhuast ports? Were you just on a mission to fuck something up?
I would maybe take a blowdryer to those spark plug holes, just to make sure you got all the shit out of there. I would also recommend an oil change seeing how theres a good chance some of the water/degreaser made its way past the rings and down into the crankcase. I doubt your ignition system happened to take a shit at the same time as you got a bunch of water into the engine, I'd concetrate on getting that shit taken care of first. Again, another reason not to trust that shitty diagnostic equipment.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-25-2006, 11:08 PM
Banned
yea as soon as it starts im going down the street to use my free oil change card. I planned on that anyways cause its time for one. But even if i get all the stuff out, the middle 2 plugs arnt throwing a spark. so i need ot fingure out why they wont spark up.
Old 01-26-2006, 12:01 AM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
new coil pack
Old 01-26-2006, 12:09 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Yea the only reson i can think that 2 plugs would be fireing and 2 wouldnt is the coil.
PS. If u come to decide that it is the coil i have one for sale
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 01-26-2006, 12:15 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
I'd say coil or if something else shorted then you could have messed up the ecu as well.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-26-2006, 01:03 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Welcome to the forums. The search button is your friend, and also, please post in the correct sub-forums.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 01-28-2006, 02:06 AM
Banned
Hey day 2, i got a healthy spark from all 4 of the plugs, but now it still wont fire.... any ideas? IM going to take off my header tommrow and see if im blowin fire or not, cause i really dont know..... any tips, things to check? hit me up! aol deadmonkeygutz or ms [email protected]
