Old 01-25-2006, 09:19 PM
Cadinrfv Cadinrfv is offline
93 GAGT 3.3L Rough at Idle
I just replaced the stock ignition coils with Summit Performance GM replacement coils, Installed Magnecor 8.5mm wires, and Autolite Double Platinum plugs.
The motor now runs a little rough at Idle. I double checked all the connections and firing order, all checked out. Double checked the Gap before i installed the plugs.
The only thing i can think of that could cause the rough idle is the new plugs are different from the previous set that the old owner installed. Previous ones were Bosch Platinum +4, all were worn some, but fine with the exception of the number 6 plug was fouled a bit.
Only thing i haven't checked is the timing, as i need to borrow a light.
Any thoughts on what might be causing it to idle rough?
Old 03-17-2006, 05:48 PM
sirrobocop sirrobocop is offline
Re: 93 GAGT 3.3L Rough at Idle
The question might be why all the parts? However, the most common culprit electrically for rough idle are:
1) Dirty Mass Air Sensor (on top of the throttle body, remove and clean very carefully)
2) Bad plug wire (feels like a tranny problem at times, oddly enough...)
Good hunting...
