Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-25-2006, 09:18 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Exclamation Interior Lighting Problem
Ok, everything was fine untill this past saturday, i thought it was just a fuse or something. but its not. so heres the deal. everything works fine, untill it gets to be night time... then i turn on the lights, and thats when the trouble starts. everything outside works GREAT! Perfect, but the inside is a different story. i have the stock Radio and it still lights different when the headlights are on, but the gauges, and the AC controls are Dark as can be... check the bulbs, everything is fine. I dont get this one, I had to ask my dad for help on this one, Hes an engineere, and really good with electronics, its got him Stumped to. anything would be great guys! i just dont get it...
Old 01-25-2006, 10:29 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Interior Lighting Problem
a short most likely
now - 2000 civic
soon - 2002 is300
Old 01-25-2006, 11:11 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
My gsx has the same problem. I'm about ready to pull my whole dash out.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-26-2006, 05:07 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Try checking the dimmer switch, not real sure what else could cause everything not to work without blowing a fuse. Does the light around the ignition work?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-26-2006, 07:31 PM
Black99GST's Avatar
AHHHH!!!!!!!!!! Thanks so much!!! i just checked the dimmer switch... it was that little son of a... Man, i just made a custom jumper connecting the black ground from the dimmer switch to the black+yellow (stock lighting negitive wire color) and everything is good again, if anyone is parting out their car and has a working dimmer switch, please let me know!!! and thank you so much SilvrEclipse you made my day!!!
Old 01-27-2006, 09:21 PM
turbotalon95 turbotalon95 is offline
you could make your own dimmer switch. thats what i did. just simply get a turn style switch and wire it up the same way you would the factory. very simple and cheap
