Old 01-25-2006, 09:12 PM
er76 er76 is offline
Not enough voltage
My dash lights brighten and dim at random. This is also the case with my heater fan, I can hear the fan slow down and then speed up again. It acts like there is not enought voltage. I went and got my alternator tested at the parts store, they said my alternator is giving more power than it should.
I think this is caused by a bare wire coming into contact with the chassis some where.
What do you think this is?
Old 01-26-2006, 06:08 PM
unbe unbe is offline
Re: Not enough voltage
A bare wire touching the chassis should blow a fuse.I'd say it's more likely a loose connection at a ground or power source.
Old 01-26-2006, 06:27 PM
Is there an easy way to test this?
The problem is more predictable when the truck has been off for a while (cold start.)
Old 01-27-2006, 05:11 PM
Clean and tighten your battery terminals,tighten all ground connections and power connections,get a diagram and read it to see what circuits are giving you a problem and what junctions they have in common.If you are in doubt of a connection perform a voltage drop test on it while it is under a load.If you tell us the year maybe someone in this forum might know something that that particular model is notorious for.I have a 98 and the only problem I had was a bad ignition switch.
Good luck
Unbe
Old 01-27-2006, 05:46 PM
It is a
93 S-10
2.8l v6
standard transmission.
