Old 01-25-2006, 09:04 PM
fleettech fleettech is offline
I can't get my change oil soon light to reset
I changed my oil tonight in my 02 silverado 4.8l and tried to reset the light. turn key on hit gas to floor 3 times(or more)in 5 seconds and the COS light will flash 5 times then go out. shut key off then start engine, battery light goes out then change oil light soon flashes 5 times then goes out(doesn't usually do that). I thought it might have something to do with swapping my stereo out so I plugged the old one back in and same results. any ideas I might be able to hook up the tech2 at work friday. I am using Castrol 10w30 high milage if it matters.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 01-25-2006, 09:07 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: I can't get my change oil soon light to reset
Mine turns out to be a bitch most times, so I really don't have an answer for you. The last time I got mine to go out, i turned the key on, pressed the gas pedal til the COS light flashed, turned the truck off, and walked away. Came back and no more troubles.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 01-25-2006, 09:11 PM
06Z71 06Z71 is offline
On my 99 I had to take off the ground wire on my battery don't ask me why but that was the trick
Cranked Bars
Silverstar headlight + 8 Light Mod
TrueFlow Intake + Airaid TBS
5% Window Tint + 30% On Front Windshield
Billet Grill + Bugshield + Ventvisors
And Still Spending
Old 01-25-2006, 09:27 PM
I just went out to try it again and its reset damn thing has a mind of its own
Old 01-25-2006, 09:54 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
Thats the answer I did the samething!!!!
Simon R
2001 Silverado W/T 4.3
124,000
Old 01-26-2006, 11:15 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
I just changed the oil in mine on the weekend and the book says to put the ignition to the run position and press the gas pedal to the floor 3 times within 5 seconds and i did that and nothing happened so within that same 5 seconds i pressed it 2 more times which made a total of 5 times in five seconds , then it flashed and was reset. Screwey kind of system if you ask me, it goes against everything you were taught and told about fuel injected vehicles and not touching the gas pedal before you start it, never mind having the key in the run position.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
