Old 01-25-2006, 07:15 PM
Dan-m-1960 Dan-m-1960 is offline
Exclamation 1989 f150 rear end gear ratio
Have a 89 ford f150 larriat, straight 6 cylinder 4.9, manual trany, 4x4, that is in need of a rear end. Called a junk yard to locate a replacement and I was asked by them what gear ratio the rear end in my truck has.... I have no idea. Any information on the stock rear end and or gear ratio for this vehicle is will be most appreciated.
Thanks
Dan
Old 01-25-2006, 08:00 PM
sreve sreve is offline
Re: 1989 f150 rear end gear ratio
most likekly a 3:55 but w a 4x4 take no chances its gotta be the same. if you have the sticker on the door jamb post the axle code
Old 01-26-2006, 01:05 AM
mechhound mechhound is offline
Also, there may be a small metal tag on one of your differential bolts. There really is no standard ratio, my 88 F-150 4X4 with your same engine and 5 speed manual has a 3.08. But as sreve said you can't guess with a 4X4.
