My question is does anyone know how to adjust the idle on the tbi setup if so please explain to me how to adjust drive and regular idle. It's a 93. Thanks
Re: Idle Question
Is your idle too high or too low? EDIT: Custom chip programming can also adjust idle and idle in drive. //2000CAYukon Last edited by 2000CAYukon; 01-26-2006 at 04:48 PM. |
Re: Idle Question
what the deal is is that the drive idle is way to low. once the truck warms up, the idle drops below 1000 and just barely above 500. So when you drive from a stop it seems like the motor is about to shut off. it starts shakin.. I had the truck serviced and tuned up at goodyear, it ran fine for about a day and then everything went to crap when the truck goes to 45-50 at normal idle within 1500-2000 the truck starts feelin like someone pulls up behind u and starts pushin u and lettin out simutaniously. The check engine light comes on and I really don't what goodyear did to get their money but they said that they did everything right.. ???? I thought about changing plug wires or o2 sensor or somthing. it just ain't drivin right
I'd rather PUSH my Chevy than Drive a Ford '93 Silverado Z71 -350- Daily Driver '76 C10 -350- (Sold) My Old Toy '80 Camaro Z28 -350- My New Toy |
Re: Idle Question
Well sice you said the check engine light comes on you need to check the trouble codes. Go here -> http://www.troublecodes.net/GM/ get the trouble codes if you can post your reseults we may be able to assist you further
Re: Idle Question
The idle air control valve does everything with the idle, unless you have a vacuum leak.
