Old 01-25-2006, 03:46 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Lowered Third Gen with Side exit exhaust-Will bottom out easily??
I wanna get these really cool dual side exit exhaust for my camaro but I'm in the process of replacing the springs and I just found a pair of rears for 30bucks(Eibach Pro) but would it be smarter to get stock springs if I have that exhaust or should I be able to tuck it in enough?
Old 01-25-2006, 04:03 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Lowered Third Gen with Side exit exhaust-Will bottom out easily??
Well with the side exit exhaust it will depend on what year your 3rd gen is. Like if its one of the earlier models without the body kit on it, it will be fine even with the lowering springs, but if its like a 90-92, the side skirts and all were like bigger than the past body kits, so you'd have to like cut a hole in the side skirts to make it fit (And it would look way better) Ofcourse you could get them to fit but the clearance would be horrible unless you get the thin slits tail pipes.
Old 01-25-2006, 04:11 PM
Dyno247365's Avatar
Someone else told me to cut a hole in the effects too, I was gonna get the dualpipe tips. It's the 87 Iroc-Z effects, about the same as 90-92 but no vents, remember?
"Vents win races"
damn I really need some signatures so people will remember me
Old 01-25-2006, 04:42 PM
Is eating.
Well then cut holes into the side skirts, and make sure you do it correctly.. so measuring is a must.
Old 01-25-2006, 08:43 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
.......what would cutting into the ground effects do? they dont go low enough to need to cut into them.....dont cut them dude.....i mean do what you want.....but i say dont cut them. If you do it right and dont get crazy with the size of the tips they will fit even with the pro kit. Buy my 4th gen tips and they will fit fine. They would look pretty sweet out the sides too.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-25-2006, 09:36 PM
Is eating.
Since the sideskirts dont hit the ground, cutting a hole into the side skirts and then having the pipes come out through the side skirt would thus not have them scrape the ground if he goes over like a bump. Also he noted that he's going to lower it because he asked if it would be better to keep the stock height
Old 01-25-2006, 11:53 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
impossible, you can't fit an entire 3 inch pipe through our ground effects... if you look to see where they attach to, there is body there, they don't extend but MAYBE and inch and a half below the lowest part of the body... if you tried to put the entire exit within the ground effects you would also have to cut the body, which is not good. plus having it inside runs the risk of maybe cooking the plastic... the point of scraping wouldn't be on the sides anyway... it would be underneath the car that it would, and unless you want to beat up the floor pan, if not then you can't do anything about that... you can't have the exhaust right up against the floor either, there needs to be some space... running exhaust underneath like that will greatly increase the chance of scrapping... there aint much you can do about it... we have low cars... if you use any pipe larger than 2 and a half you will have real issues... if you want it to look clean then maybe you can trim the bottom edge of the effects in like a half circle shape and bring up the exhaust so the top part fits into the effects... that would be possible i suppose. you'll still have scrapping issues underneath the car however...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 01-26-2006, 12:45 AM
Is eating.
Actually now that I remember, the cross eyed man is right. Our side skirts dont come down much from the body.
Old 01-26-2006, 11:33 AM
gee thx...
Old 01-26-2006, 12:07 PM
run dual 2.5" pipes. That will breath just fine for your motor and it should fit under your car. ........then you can buy my tips.....
Old 01-26-2006, 12:28 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
One speed bump or low approach and bye bye exhaust...
my 4th gen bottoms out just with long tubes.... I can't imagine what it would be like with pipes that low... It would look good but Functionaly I don't think it would work...
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 01-26-2006, 12:43 PM
Im not saying it wouldnt rub from time to time but hes going to have to take it very easy over bumps anyways if hes going to lower the car
Old 01-26-2006, 12:50 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
heres some pics of the setup that was on my 87 iroc camaro. true duals 2 1/4in. i could go over speed humps with no problem but not tall speed bumps.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 01-26-2006, 02:42 PM
Dyno247365's Avatar
I appreciate everyone's help, this may take some more thought than I once considered.
Old 01-26-2006, 02:49 PM
i forget which magazine did it, but i've read about a flow test difference between dual 2 and a half, and single 3... they flow numbers were nearly identical... a single 3 in exhaust (like mine) doesn't really have any disadvantage to someone who ran true dual 2 and a half
