Old 01-25-2006, 03:26 PM
hytwr1 hytwr1 is offline
coil pack testing
Anybody on the forum know the specs for testing an Escort coil pack? Haynes doesn't tell you.
The Autozone site says .4 ohms minimum resistance between VBat and C1 or C2. Is this correct?
Thanks
Old 01-26-2006, 08:04 PM
dougand3 dougand3 is offline
Re: coil pack testing
Never tested my 93 1.9L coil pack but did my 98 3.8L Windstar...it has 4 leads. You check the pos lead on the outside against each of the 3 neg leads. I got these 3 resistances and went to autozone...had them pull a new coil pack and checked these resistances. Compared the 2 coil packs and they were within 5 % of each other, so my coil pack was good.
83 MB 300SD - 305k miles
93 Escort 1.9L LX Wagon - 220k miles
95 Isuzu 2.3L P'up - 230k miles
Old 01-28-2006, 02:11 PM
In did the same thing via Autozone. Mine checked out ok too.
Thanks
Old 01-28-2006, 02:14 PM
I did the same thing via Autozone. Mine checked out ok too.
Thanks
Old 01-28-2006, 02:40 PM
RahX RahX is offline
you cant really ohm test a coil pack. unfortunately the best way to test a coil pack is to do a known-good swap test. ive never been able to sucessfully ohm test a coil pack since most of them fail on the secondary windings when there is voltage present. an ohm meter cannot recreate this situation nor can it test it even if the situation was present.
Old 01-28-2006, 05:16 PM
Another thing to try is an inline spark tester...it goes on one plug and the plug wire boot goes on tester...has a window to see the spark...repeat for each plug. Not real quantitative but if light is dimmer on one plug, may indicate coil isn't sending enough juice to that plug. Harbor Freight had them for $1.99.
Old 01-29-2006, 06:48 AM
Bought the inline tester from HF. $5.99. Will give that a try.
Thanks
Old 01-29-2006, 08:55 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
just read the back tells you what to set the gap space at for certain applications.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
