Old 01-25-2006, 01:59 PM
GITZY GITZY is offline
98 F150 Re-charging Problems
Have A 98 F-150 4.6l Battery Light Went On Then About 1/2 Hour
Later Headlights Go Dim Volt Meter Is On Zero No Accessories Work.take Battery And Alternator To Have Tested They Both Check Out Alright.have Checked All Connections For Tightness And Being
Clean.all Looks Ok.why Is My Alternator Not Working??????
Thanks Tim
Old 01-25-2006, 05:35 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 98 F150 Re-charging Problems
Check all the fuses, there is a charging fuse under the hood in the fuse box. I think it is a 20 amp ATC fuse. Here is a pic of charging system.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 01-26-2006, 11:17 AM
Thank You Very Much
I Will Post Results
Great Site For Info
Old 01-27-2006, 01:39 PM
Way2old Was Right On.two Fuses Bad And A Short In The Wire
From The 20amp Fuse For Voltage Reg.loacated Under Hood
Passenger Side By Firewall.the Other One 20amp Underhood
Drivers Side Near Radiator.
Thanks Way2old
Old 01-27-2006, 01:58 PM
way2old's Avatar
TOKEN HILLBILLY
Cool. Glad to be of help. Drink Makers Mark.
