1994 Pont Trans Sport bulb
Ok, try and make this simple. The bulb behind the Climate Control panel (the one with A/C, Recirc, Upper, B-Lev, Off, Lower, Mix, Def buttons) must have burnt out. I would like to replace it, and was hoping someone has step by step instructions on how to replace it. I espect I will have to take a few things off , to get to it, but would appreciate some instructions.
Thanks Paul |
Re: 1994 Pont Trans Sport bulb
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629 I don't believe in miracles. Last edited by LMP; 01-26-2006 at 06:24 AM. |
THanks LMP, but a few questions:
I cannot make out what it says, after #7, remove or connect. I cant make out what the next #1, and #2 is, under Install and Connect. It then goes up to #3, under Tighten. But it starts off "Climate Control Components" Heater-A/C Control Assembly Figure 21 Remove or Disconnect then # 1-7. Then I cant make out the next 3 lines It appears the first line is Remove or Disconnect 1. ? 2. ? My next question is, am I to presume the backlight bulb , to light up the 8 push buttons, is right inside the Control Assembly Heater-A/C? The diagram doesnt show the bulb, so I am not sure. Also, if you dont mind, would you also have the diagram/instructions to replace the turn signal lever? THanks I appreciate it!! |
to change bulbs you have to open control assembly, solder burned bulbs off the circuitboard and solder new bulbs back. Been there, done that. I found new bulbs from a local electronics part shop.
Wouldnt the bulb just be a plug in type dashboard light? |
. But it wasn't a bad job, I didn't have any instructionsQuote:
http://www.accu-doc.ch/accuasp/rootc...43/default.htm. I'm quite sure it was 14v bulb, but it is easy to figure out by checking the cirquitboard. |
Thanks for the answer. I have to repair the backlight, and this was great input.
Does anyone know if the in steering wheel radio controls have any back light. There is no light at all in my steering wheel radio controls, Is there any light to repair? |
When the headlights are turned on, all 8 buttons light up, or there should be some sort of backlight , so you can see which button is which button. Thusly I suspect there is a separate backlight, and each button has its own LED? Anyone confirm this? Thanks. Paul |
(and my name is Antti )
I just checked out my 94 Transport HVAC control panel and there are four minature lamps soldered to PCB to provide backlight. (Pushbutton indicators are amber LEDS). The grey wire is the feed and adjusts from zero to 10.5v via the dimmer, so must be 14v. I am not familiar with the L3215 IVP lamp, although the dimensions are the same 3.15x6.35mm, I have used model train "grain of wheat" lamps before. Hope this helps.
