Go Back   Automotive Forums Car Chat > Plymouth > Breeze
Old 01-25-2006, 12:50 PM
Martsy Martsy is offline
Exclamation 96 Breeze wont start?
car ran fine yesterday and now i turn the key and nothing happens, only a light comes on in the cluster that looks like this (!) i looked in the manual and it says nothing about that? anyone know what could be wrong?? i tryed turning the key back to the acc position and the radio wont turn on either? something related to why it wont start??
Old 01-25-2006, 04:49 PM
Re: 96 Breeze wont start?
fuse under the hood for the fuel pump.
Old 02-06-2006, 11:55 PM
mcrosby mcrosby is offline
Do you mean you found the problem and it is the fuse under the hood for the fuel pump?
Old 02-21-2006, 02:33 PM
yes? haha
Old 03-23-2007, 08:30 AM
t.forsythe t.forsythe is offline
Had the same problem yesterday and fixed it...I replaced the fuse, but it blew again. I disconnected the small wire at the starter, replaced the fuse and it still blew...that means a short in the wire from the fuse to the starter which takes out the fuel pump and who knows what else! I pulled apart the engine harness and found the brown wire at the corner of the cylinder head was bared and shorting against the block. If you find this problem and no wire strands are melted, just tape the wire up good and you are gold. I had to cut the bad piece out and solder in a new wire. All fixed.
