i need some help, i have an 87 crx si and want to swap in a jdm b16. im not sure about a couple things like, should i go with obd 0 or obd1, what will i need as far as front suspension and front knuckles are concerned. i know i need custom shift linkage, axles, vtec wireing, an mounts. how much will a low milege b16 sell for and finally what else will i need to make this work, iv heard parts from an integra are required but im not sure. i have about $3,000 waiting to be dumped into this progect please help ASAP. thanx
Re: b16 + 87 crx si = ????
B16 + 87 crx si = $$$$
You'll be spending at least $3000, unless you can find a ridiculously cheap motor and tranny. |
Here you go can't be anymore specific http://http://www.redpepperracing.co...oman/album608/
and don't forget to join redpepperracing.com if you already haven't it's the 1g crx safe haven
If you don't live for something, you live for nothing
i got a 87 honda civic dx and i did the b16a swap my self and my buddy did the harness for me took him like three hours to do the harness i went obd1 with a chip p28 just need hasport motor mounts,hasport cv joints from jdmcars.com is cheaper with those people and 86-89 shift linkage,hubs mine was carb so i had to buy a fuel pump and change the fuel tank for a 87 si fuel tank and a fuel return line and if you go obd1 you need a speed sensor.clutch cable from a 86-89 acura integra and gas pedal cable from a 90-93 acura integra the upper radiator hose from a 99-2000 honda civc si need some modification and the lower hose from a 90 acura integra need the rear transmission bracket from a 99-2000 honda civic si and the cv joint mid shaft from 90-93 acura integra ls and much more..........
