Old 01-25-2006, 09:48 AM
superman3405 superman3405 is offline
Exhaust Manifold VS Headers
I have the exhaust manifolds pulled off of my 350, I needed to replace gaskets. They are pretty rusted up and I am considering sandblasting and painting to clean them up. Before I do that I wanted to know what are the major differences between manifolds and headers? Are there any benifits to having headers as opposed to the Exhaust Manifolds?
Old 01-25-2006, 10:01 AM
g_rod66 g_rod66 is offline
Re: Exhaust Manifold VS Headers
the differance between headers and manafold it headers let the exhaust flow out better. it can increase horsepower, too.
1994 silverado z71 stepside
1999 cav z24
1991 honda crx si (for sale)
Old 01-25-2006, 10:09 AM
tom3 tom3 is offline
If you do want or need more performance, the headers are a good deal. For everyday driving they are probably more trouble than they are worth. Expense, fitup problems, underhood heat, noise.
Old 01-25-2006, 05:20 PM
bighillman bighillman is offline
Another common problem with headers is the fact that it seems to be a problem keeping them from warping and blowing exhaust gaskets.
Old 01-25-2006, 05:33 PM
Elbert Elbert is offline
if your truck is otherwise stock then I think headers are mainly a waste of time. Installing headers even in a truck is a pain in the @ss. Expect to have exhaust leaks, and sometimes the A/C bracket is a half-@ass setup (AC bracket or PS bracket) depending on what year truck it is.
If you have a stock truck then I think your money would be better spent elsewhere. IF you do install headers save your manifolds in case you have a change in plan later.
Old 01-29-2006, 01:14 AM
DrededSS DrededSS is offline
Send a message via AIM to DrededSS
If you should decide to go with headers, use the edelbrock shorties. They're easy to install, and I finally had a donut gasket blow after 2.5 years. I replaced it with a full-metal piece and never had another problem. An occasional check for the tightness of the bolts, perhaps at oil change time, will ensure you have very few problems.
Dred
Old 01-29-2006, 08:33 PM
67malibu 67malibu is offline
I'd agree with going with the shorties. Most are direct fits, including AIR (if you have it) and O2 fittings. When I boogered up the threads with a slightly bent stud on my '88, I found that a set of cheap Flowtechs (~ $160, five years ago) were cheaper than just the one manifold from a junk yard (searched alot of them.) They lined up with the stock pipes, did not need a head pipe gasket and the only leak in five years has been a blown gasket on one side. I went with the metal reinforced gaskets and haven't had another problem. Benefits, mainly you gain a little torque in the low end and perhaps some horses up top were most trucks spend little time. Fitting them in was relatively easy (full length headers, totally different story) but if you want to changes the plugs for numbers 5 and 7 the passenger header has to come off.
