Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-25-2006, 02:08 AM
BlackFalcon BlackFalcon is offline
new guy with a used 98 rodeo Ls 4x4
hi all
i picked up a 98 rodeo Ls 4x4. i knew it may have some things that it may need to be fixed (as with any used car)the thing that is most predominant is
the noise under the hood at first i thought was a tensioner pully.my 01 chevy sounds the same when it rains and it sits over night.nope
pullys good. the sound seems to be coming from just behind the thordle body
i keep centralizing on the manifold i suspect that there might be a air leak,or posiblely some hose or conection loose there,most times when i start it it surges between 750 and 1500 rpm 2-3 times and dies, restart and keep the foot in the gas for a few and then fine. does any body have any ideas
or have herd this thing before?
98 3.2 v6 107k miles 4x4 unknown service history
Old 01-25-2006, 05:13 AM
rodeo02 rodeo02 is offline
Re: new guy with a used 98 rodeo Ls 4x4
This is a bad intake manifold gasket. They are a thick plastic type material that often break. You get the symptoms you describe from the vacuum leak. If you trace where the common chamber runners meet up with the cylinder heads, that's where the IMG(s) are. One per side.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-25-2006, 11:22 AM
amigo-2k amigo-2k is offline
Isuzu Guy
make sure you read on the FAQ's for thing to watch out for on your new truck.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-25-2006, 12:58 PM
directory's Avatar
directory directory is offline
yes, follow the FAQ's website, and read up on this truck....also ask arond this forum for anything. it's wonderful!
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
