Old 01-25-2006, 12:26 AM
MSimpson MSimpson is offline
Ignition or Fuel Pump?
I really didn't start having this problem until this winter, but only sometimes when I try to start my Blazer it wont start and I will get like a loud whining noise like it wants to start but wont. But if i immediatly turn if off and turn it back on it fires right up. Any ideas? It seems to be worse is really cold wheather..
Old 01-25-2006, 06:34 AM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Ignition or Fuel Pump?
You might want to try putting the key in the "run" position for 5 seconds before trying to start the truck. This will let you know if it's a fuel pressure problem,as it will allow the pump to build-up pressure.
You might also want to list the year,model, and engine type. Just might
help you get a quicker response from someone whose had a similar problem.
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 01-25-2006, 07:19 AM
Southern Comfort's Avatar
Southern Comfort Southern Comfort is offline
Sounds like your truck isn't holding the fuel pressure after it sits for a while. You need to check your fuel pressure system. I believe the instruction is in the how to section on this forum.
SC
