Old 01-24-2006, 09:04 PM
lady_x_calibur lady_x_calibur is offline
Send a message via Yahoo to lady_x_calibur
Tapping loud, not a knock but had a lot of work done recently...
1997 Chevy Blazer LT AWD 158,000 miles
-Replaced radiator, heater core cleaned out due to overheating problem/sludge from Dexron, also had manifold gasket replaced due to minor pressure leak just in December 05'.
-Had some suspension work done this month (Jan 06') most likely not related.
There was a very light/almost indistinguishable tapping sound right after I got it back in Dec. from repair, but it didn't seem out of the ordinary.
Now, I am hearing a loud tapping (I am not calling it a knock because it does not sound like someone is hitting it with a hammer). The noise is prominent when sitting idle, and does increase in repetition with acceleration.
My first guess was a lifter, or valve? But upon reading other threads is it possible this is an exhaust issue?
I say this because I did hit a pretty big ice pocket/hole the other day which slammed me down. Possibly the tapping had been going on as loudly before, but I hadn't noticed it until after this. Could be wishful thinking.
-Checked oil, fluids immediately, level was good, was clean. Had it changed and added Slick 50 just to be safe. Noise/tapping did not decrease at all.
After oil change, service engine light came on next day, and maybe I am imaging it, but I could swear exhaust is coming in through the vents. I do not know the codes yet, need to take it in.
Anyone know what I am dealing with here, so I can be well advised before taking it in? I appreciate any input...Thanks, Carie
Old 01-24-2006, 11:02 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Tapping loud, not a knock but had a lot of work done recently...
Exhaust is the last thing that people check, but I've been finding that it should be the first place to look.
If it's the exhaust it'll either be a leak right at the engine or the manifold might have a hole or crack in it.
If it isn't exhaust it'll be a lifter.
Good Luck
Old 01-25-2006, 01:38 AM
Rmbodie's Avatar
Rmbodie Rmbodie is offline
If you are smelling exhaust thru the vents , you probably have an exhaust leak .This could be dangerous ,CO gas !!!! Since you say it was overheating , the manifold could be cracked or seperated from the engine block somewhere . The EGR valve may not be tight . Some things have to be retorqued after a reassembly. Rob
2000 Trans Am six speed Blackbird .Fast enough stock!
2005 Grand Prix.
2005 2500HD Silverado 4x4 , Duramax!!!!!!! Lifted ,Pumped,Humped,Thumped!
1988 JEEP Cherokee: Lifted, Sons new toy.
Old 01-28-2006, 08:59 PM
Thanks for the help all...
It quit on me the other day, needed a fuel pump. Mechanic says knocking is a lifter, but not to worry about it !/? ha ha...
I am going to try to quiet the noise best I can by running synthetics through, etc...
If I cannot get it to quiet down, I will have to do the lifters because this noise will drive me bonkers. Mechanic says it will run approx. $400-$500.
Again, thanks all!!
Old 01-28-2006, 09:42 PM
Banned
Can you get us an audio clip of the motor running.
I just don't trust mechanics that say to not worrry about it.
Old 01-28-2006, 11:16 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
It could be something as simple as a leaking exhaust at either where the manifold connects to the exhaust y-pipe, or at the exhaust manifold itself. I would bet on the first one, its common for an exhaust leak to start there and since you said to hit something, you probably dislodged it even more and created a bigger leak. You will get a tapping sound much like a lifter but it the exhaust valves closing. It would be like a clanking/tapping sound, usually(but not always) its louder when the engine is cold.
