Old 01-24-2006, 08:38 PM
fujiwara takumi fujiwara takumi is offline
how did i do this?
little pin holes all over certain areas of the car, looks like perforation, almost like bubbles that popped and never filled in.
is this from spraying too thick?
if necessary ill try to get pics, but the car is still drying.
Old 01-24-2006, 08:41 PM
freakray freakray is offline
AF Modelrater
Re: how did i do this?
Can be from spraying too thick, could also be from any number of other reasons.
Rather post photos if you can
AF User Guidelines
Old 01-24-2006, 08:42 PM
blubaja's Avatar
blubaja blubaja is offline
Solvent pop. Did you clean the body thoroughly before you painted the color on it?
Old 01-24-2006, 08:59 PM
before primer with soap, after sanding primer i rinsed.
Old 01-24-2006, 09:07 PM
pics:
http://beatmotorsports.com/racing/ma...g2_itemId=3174
gf is a paint chemist, says the ambient temps were too high causing the top layer to dry too quickly.
she says its craters, not solvent pop, caused by the primer not coalescing. i used model masters white primer with a model master black topcoat...
Old 01-24-2006, 09:12 PM
MidMazar's Avatar
MidMazar MidMazar is offline
looks to me like the the surface wasn't cleaned thoroughly, i dont think it was too thick of a coat. What temp was it?
In Progress
Old 01-24-2006, 09:21 PM
under 80, maybe 75-78. i turned the radiator up in the room and left the model within about 8". it was not uncomfortably hot, just cooler than a heat lamp.
Old 01-25-2006, 01:13 AM
Asmenoth's Avatar
Asmenoth Asmenoth is offline
AF Premium User
That happened to me once with a clear coat. A friend of mine told me that he was told it is caused by little bits of moisture getting caught between the layers. It evaporates and a crater is formed. Now I don't remember water misting in the air at the time, but it might have been due to humidity.
Do you know how fast you were going son?
No Officer, the speedometer only goes up to 85.
Old 01-26-2006, 01:33 AM
20V_AE82 20V_AE82 is offline
Humidity causes this. Try spraying in a low humid area if possible. I always have my air con running when painting to help take the humidity out of the air.
Old 01-26-2006, 08:29 AM
Vric's Avatar
Vric Vric is offline
If you would use an airbrush, I would say you have water in your air, but in spray can... It could be humidity, or a too tick paint coat.
Old 01-26-2006, 10:48 AM
it's the middle of winter in wisconsin and i have electric baseboard heaters, i dont know the meaning of humidity.
im going to guess it was too thick. i sanded it out, buffed it, did a fresh topcoat of black that came otu really nice and cleared it. should be good now.
Old 01-26-2006, 11:00 AM
Martbee Martbee is offline
Too thick or too near from the surface. Happened to me 2 times on the same Miata ! Like a curse or something.
Old 01-26-2006, 07:27 PM
Raceman Raceman is offline
was the body cold and the paint warm when you painted?
