Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-24-2006, 07:55 PM
benjamingears benjamingears is offline
Idle Adjustment 2000 eclipse
I have 75K miles on my 4cylinder eclipse and it idles really slowly. I replaced the spark plugs and wires and it still idles really slowly and if you turn on the ac in stalls. The dealer plugged it in and said no 'codes' appear at all and nothing is wrong. How can I get it to idle faster?
Old 01-24-2006, 08:06 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: Idle Adjustment 2000 eclipse
Is yours a 2000? Because if so wrong forum...But if its a 1g or 2g there's a screw on the throttle body you can adjust.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 01-24-2006, 10:43 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Don't they have the same idle adjustment screw on the throttle bodies of the 2000+ Eclipses too?... Oh hey, look. My Haynes Manual... Lets see what it has to say about the 2000 Eclipses... Hmmm... Ok, it sounds to me like your TPS (throttle position sensor) could be going bad. Here is how you can test it to see if its going bad...
1. Unplug the plug going to the TPS.
2. Take an ohmmeter and connect it to pins 1 and 3.
3. Slowly move the throttle from fully closed to fully open.
4. Your ohmmeter should change smoothly as the throttle valve is moved and the readings should stay within 3.5 - 6.5 k-ohms.
Hope that helps ya out.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
