Old 01-24-2006, 07:04 PM
wayne64 wayne64 is offline
Very strange happenings
with the girl friends 96 S10. five months ago the start function of the ignition switch took a dump. She needs the truck for work so I hooked up a simple start button as a temp. Last month I bought a new switch and since the button was working fine I would do the job in the spring. So the other day my Frans daughter got in the truck turned the key and it started as it did before?? So I guess after a few months rest it healed it's self.
Old 01-24-2006, 11:06 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Very strange happenings
I wouldn't hold my breath on htat.
Ignition switches are weird that way. 1 day it works the next day your stranded. 10 min later it might work again.
I believe that it's usually dirt on the contacts that stops them from working but I've never taken them apart to find out.
Old 01-25-2006, 12:17 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
97 has an airbag, please please please handle the wheel like it is a loaded 12 guage at your face, because it is, disconnect the battery, pull the sir (stands for supplemental inflatable restraint, the air bags) fuse and walk away for a half an hour, minimum, get the puller you need, 4 screws in the back get the bag out, and dissasemble as you see needed, be careful and pay attention, a new tumbler (what she needs) from gm is like 30 bucks, bring the vin number, and you should be able to get one that has your door lock on it
