Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-24-2006, 05:15 PM
akalima akalima is offline
Please help me rich fuel mixture.
I have down a half dozen searches and looks like there is a common problem with the early model rodeos. With all the posts i have not come up with a straight answer for the solution. Same problems 3.1 v6 is idleing rough running way rich and backfiring. I lost my muffler and thohgt that ws the prob got new one and now engine light stays on and lack of power. Disconnected the battery power to reset cel and before i even started the engine light came on. so wha tis it the o2. This seems like to common of a problem to nto have an answer for it thx
Old 01-25-2006, 05:17 AM
rodeo02 rodeo02 is offline
Re: Please help me rich fuel mixture.
I think the 3.1's adjust the fuel trim primarily with the manifold absolute pressure (MAP) sensor. I'd look into that.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 01-25-2006, 01:14 PM
So if that were the case if i had a exhaust manifold leak that would mess up my air fuel. @nd were is the stock location for the o2 sensor?
Old 01-25-2006, 01:23 PM
1) No. 2) Threaded into the exhaust pipe, just upstream of the catalytic converter.
G/luck
Joel
Old 01-25-2006, 01:34 PM
any suggestions on how to bust that o2 sensor loose. Its looks like it the origional one i thought it was welded on
Old 01-25-2006, 02:36 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Soak it down with some powerblaster to free it up.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 01-26-2006, 08:44 PM
K Changed The O2 Sensor (pain In The Ass) And Still Running Like Ass. Made Sure All Vaccumm Lines Are Hooked Up. And Not Sure Were The Map Sensor Is
Old 01-27-2006, 12:31 PM
..Not Sure Were The Map Sensor Is
I believe it's mounted on or near the air cleaner housing on the GM 3.1L It's got two vac lines on it and is a small black box looking thing- IIRC. Autozone.com has some pretty handy parts location diagrams once you put in your year/make/model/engine info.
Joel
