Old 01-24-2006, 01:12 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
new sub box and door panels
just finished my door panels and about done with the sub box. i still have to build the cover for my capacitor in the center of the truck. i removed the 6 1/2 components and replaced with 2 6 1/2 alpine r's. in the back put a jbl 1200.1 sub amp and a mtx 7804 4 channel, all mounted behind the rear seat for security and more room. let me know what you guys think.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 01-24-2006, 01:40 PM
xpunter83 xpunter83 is offline
Re: new sub box and door panels
that looks awesome man, how does it sound?
Old 01-24-2006, 01:51 PM
chuck16's Avatar
chuck16 chuck16 is offline
Wow, man. That looks tight. Nicely installed my friend. I've been thinking of some way to try and tweak the back door speakers. Haven't pulled the panel off yet to see what's behind-em. Again nice install man.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 01-24-2006, 01:54 PM
xpunter83 that looks awesome man, how does it sound?
it sounds really good.
thanks for looking and the rear doors should have 4x6 inch speakers.
Old 01-24-2006, 07:25 PM
onehate02 onehate02 is offline
Send a message via AIM to onehate02
that does look great. i want to do something just like that. did you have to make an amp rack or can you just screw the amps in behind the back seat? how do those type-r's sound, are they components?
2004 Silverado ext. cab 4.3L
Pirelli Scorpian A/T 275's
Magnaflow straight-through muffler (dumped)
K&N FIPK
Custom sound system (alpine/infinity/monster)
Billet Grille inserts & bowtie
Xenon blue bulbs (high/low/drl)
Limo Tint all around
Gaylords X-2000 tonneau
Rhino bed liner
Code Alarm keyless entry system
Custom PA system (dual speakers)
A1 Power Window mod
Center console swap
Old 01-24-2006, 09:00 PM
kenwood guy's Avatar
kenwood guy kenwood guy is offline
Send a message via Yahoo to kenwood guy
I got a question is it possable to swap the rear speakers with 6x9's would it even sound better??? when I had my caprice the back had 6x9s and I got use to them behind me I just wonder if there is a way nice setup sport how did you get your driver side door panels to look like that?? did you just drill through the panels and mounted them??
Simon R
2001 Silverado W/T 4.3
124,000
Old 01-25-2006, 07:33 PM
i took a piece of 1/2 inch mdf and cut it to fit the back and then covered it in speakers box carpet to make it look better. if it was going to be seen i would have made it look cleaner but i am happy with it. the type r's sound really good, and they are just the coaxials from last year but they have crossovers and hook up just like components do.
Old 01-25-2006, 07:38 PM
i don't know of any way to sawp the rear speakers for anything other than
4x6's. that is one of my next projects over the next few weeks hopefully. the door panels where a pretty good amount of work. i took the panel off and pulled the grill off, then i took the grill onto a piece of 3/4 inch mdf and traced it out. then i had to cut the factory tweeter hole bigger. i wrapped the wood in carpet for padding to fill in any bumps in the wood then i bought some vinyl from the fabric store and covered them and screwed them into the door.
Old 01-25-2006, 08:16 PM
so the section around the door speakers is what you made??? on my truck I have the speaker then grill over it (towards the floor) then its just a big empty space up towards the handle of the door did you just lay that piece over??? looks awesome man
Simon R
124,000
Old 01-26-2006, 09:28 AM
this is what my factory panel looked like, you probably have the more standard door panel. they made 2 different styles. mine had factory components.
Old 01-26-2006, 04:44 PM
Now I see!!! that looks kool man would I have to change the panel to do something like that???
Simon R
124,000
Old 01-26-2006, 08:21 PM
ya if you wanted to make them look like mine you would need new panels. you could make the ones you have work but you would probably have to fiberglass them to make them form to the door and make the speakers fit.
Old 01-28-2006, 09:45 AM
Yellow Snow Yellow Snow is offline
Send a message via MSN to Yellow Snow Send a message via Yahoo to Yellow Snow
I love what you did with the door panels, I would have never thought of that.
I actually just bought my 2001 1500(5.3L) a week ago and have been thinking of ways to add some subs under the rear seat for the same obvious reason, to save space. I was thinking two seperate boxes under the back seat, but the one solid box would be more stable in rough conditions.
Just a few questions...
On the Sub box did you make it one solid unit? Or is it basically two seperate boxes connected together? I tried to figure it out from the pics you have posted and it's to hard to tell. Didn't know if maybe it would mess up the air volume of the box. And do you have it mounted in any way to the vehicle, or is it just fit to the space under the seat so it stays in place without mounting? That's one of my biggest problems with just throwing a sub box in the back seat is that it just bounces around where ever it decides to, and if I were to brake for a deer I'd have a box bouncing off my seat, which in my opinion is unacceptable.
Old 01-28-2006, 10:06 AM
thanks for looking at post. the best way is to make it all one box. mine is all one box but i had to work around all the wires in the middle for my cap, if that wasn't going to be right there it would have been alot easier. my seat just lays on top of my box, it is not mounted down at all. but it doesnt move any at all. if you go to www.audioenhancers.com they have alot of different boxes for our trucks, you can order them at any circuit city store, or just build them from the specs they have online, that is if you want to spend the time cutting and screwing the box. make sure if you build it yourself use 3/4 inch MDF and use some kind of good sealant, like liquid nails or nail power.
Old 01-28-2006, 06:25 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Talk about going all out. I bet that shit is LOUD! Looks cool man.
*Under Construction - New sig to debut*
