Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 01-24-2006, 12:38 PM
sthayer sthayer is offline
Question would not start
I have a 1995 plymouth neon - went to start it this morning, it tunred over good, had fuels - just not starting - after check fuses, plugs, etc. I found a old spark plug - pulled the boot off of each plug - went through all 4 of them - they all spark - this is about 2 hours after I first starting fighting with it - about the 3rd. plug - it tried to fire - put it back, check the 4th plug - turned it over, and it started - real rough at first, but still started - idles a little rough, and it has not been getting good gas mileage.
I am not sure if it something with the cold weather - it warmed up quite a bit from when if first started, or what.
the only codes it is showing are 11 (battery disconnected), 21 (O2 Sensor problem - I am asuming this is the mileage problem)
Need to figure out what happened this morning, so It wont happen again.
Thanks,
Scott
Old 01-24-2006, 01:40 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: would not start
What milage problem? It might be time for some new plugs, even though they are working, they may not be working great.
Old 01-24-2006, 02:51 PM
Re: would not start
I am thinking with the O2 sensor not working right - that is causing the low gas mileage. The car had a major tune up about 6 moths ago - new plugs, wires and everything goes along with that.
Before the tune up, when you would press on the gas - it would hesitate - jerk a couple of times, and then take off - and did the same thing going up hills - tune up helped that a lot - but it is still once in a while a little bit - read someplace this could be caused by the crank position sensor - could this be the problem with it not starting?
going to go out once it cools off out thier tonight - and see if it the cold that is the problem - it starts just fine, no problems now - but it a lot warmer out thier than it was.
Old 01-24-2006, 04:26 PM
Re: would not start
Have you replaced the O2 sensor or at least checked to see if it's seated properly?
Old 01-24-2006, 04:39 PM
Re: would not start
have not looked at the O2 sensors yet - there are two of them - that is only thing that the comp. if showing a code on.
just went out - was very hard to start - but once it got started, ran just fine.
would the O2 sensor make it hard to start when it is cold - if I just get it started once, I can start it just fine, but once it gets cooled off again, will not start like it used to.
Right now, hate to spend $60.00 each on them, and not have solve the starting problem.
Old 01-24-2006, 04:46 PM
Re: would not start
If it is an O2 sensor problem, then more than likely it's your upstream sensor. Replace that one first, reset the PCM and see if that takes care of your problem.
Old 01-24-2006, 04:55 PM
rsublime4life's Avatar
rsublime4life rsublime4life is offline
Re: would not start
Its not an O2 problem. When cars are cold most ECUs dont even look at the O2. They run a closed loop until they get hot. My guess is poor spark. Check the coil? Or maybe cam timing, but I dont know if those engines have a timing belt or chain. if its chain then odds are the cam timing is correct unless it's been apart recently. if its a timing belt it could have jumped a tooth on the cam.
Old 01-24-2006, 10:48 PM
Re: would not start
When was the last time you worked on a neon? If the timing belt skipped a tooth, then he would have gotten a code 11 and maybe have bent some valves.
Old 01-25-2006, 01:21 AM
99 Neon R/T 99 Neon R/T is offline
Re: would not start
Not to undercut you but didnt he say in the opening post that he got a code 11?
If it aint broke fix it till it is.
Old 01-25-2006, 02:16 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: would not start
I thought code 11 on a '95 chrysler product was IGN reference signal, which I believe is the crank sensor..
That would be open loop until hot..And yes, the ECM will ignore the O2's until closed loop.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-25-2006, 07:45 AM
Re: would not start
You're right, he did say he got a code 11, but said it was the battery thing, so I didn't even think about it.
Well, code 11 is for Timing belt skipped 1 tooth or more from initial learned value; Intermittent loss of either camshaft or crankshaft position sensor;
No crank reference signal detected during engine cranking.
sthayer, if you indeed have a code 11, and your timing belt skipped a tooth, then you could have some big problems on your hands. You need to get scanner so you can get the P code. It will be more specific.
Old 01-26-2006, 01:41 AM
Re: would not start
Aren't (P) Powertrain codes reserved for OBDII '96+ only?
Old 01-26-2006, 07:37 AM
Re: would not start
All Neons, including all 95's manufactured as far back as February, 1994 are OBD-2 compliant.
Old 01-26-2006, 12:09 PM
Re: would not start
WOW! Gee, das, it doesnt seem like i was totally talking out of my ass now does it.
Old 01-26-2006, 01:19 PM
Re: would not start
What are you talking about?
