Old 01-24-2006, 12:08 PM
Bowtiebrat Bowtiebrat is offline
Question S- 10 injector spray prob.....PLZ HELP
I have a 92 s-10 4x4 4.3 w/5-spd. The problem is it runs fairly good cold but when it warms up the fuel spray quits intermittently. After it warms up the injector stops spraying fuel. I have replaced fuel pump, sending unit, map sensor, tps, distributor, cap, wires, plugs, fuel filter, plugs, fuel pressure regulator diaphram, still dont know what the problem is.
Old 01-25-2006, 12:07 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: S- 10 injector spray prob.....PLZ HELP
well gussing its the ecm or injector itselfe
Old 01-25-2006, 07:47 AM
with the new map hooked up the fuel momentarly quits, but i now have it unhooked and it runs but not like it should
Old 01-25-2006, 11:26 AM
camohog1 camohog1 is offline
You know as stupid as this sounds have you put any fuel injector cleaner in?. You may also try changing the fuel injector as well. Not tryin to insult your intelligence but sometimes the simple things get overlooked.
Old 01-26-2006, 05:10 PM
yes, have been thru about 3 bottles of inj cleaner. i even changed the distributor, cap, wires, everything i could think of, but nothing has worked, so far..
Old 01-26-2006, 08:19 PM
that much cleaner is hurting you, injector cleaners (and every other gas additive) contain patrolium distallets that will clog up injectors if used to much, we reccomend once every 6 months at the most for injector cleaner, and once every other for dry gas if you need it
