Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 01-24-2006, 11:12 AM
workingout's Avatar
workingout workingout is offline
'96 Burning Alternator Belts: Do I need 2 RnR
I have gone through two Alt belts in three months. The Alt is still working fine, charging and providing power, yet it squeals like a banshee when the temp is below freezing.
I was quoted $165 plus an $80 core charge for a replacement. I hear that the RnR for an Alternator on the sephia is not pleasant.
My question is; do I really need to replace it if its still working?
Is the squealing a sign that its about to go bad?
Old 01-24-2006, 02:03 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Re: '96 Burning Alternator Belts: Do I need 2 RnR
squealing is normally a loose belt. I have also heard alternator sing like that when they are put under a heavy load.
For 165 bucks I would have it done. I work at the dealer and cant get a price on an alternator installed for that. I couldnt even do it myself for that price.
They arent that difficult ot remove. Just have to know tricks of the trade.
Old 01-24-2006, 06:32 PM
workingout's Avatar
Re: '96 Burning Alternator Belts RnR
Its not a load problem. The car has no after market equt. The head lamps are off. its only when atmospheric temp is really low...
Can pulleys stick in cold weather?
OR is a loose belt something that will squeal more in the cold?
Old 01-25-2006, 06:56 PM
cbeck cbeck is offline
as I understand it, when cold, the rubber is more brittle/hard, and more prone to squeal or slip if loose...
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 01-26-2006, 12:23 AM
workingout's Avatar
Well I replaced it. and it works like a champ. And I can now do a PS/AC belt in record time.
if your doing this in your driveway, Just pull the axel right off the bat. have a can to catch diff oil as the axel comes out. it will drain about a 1.5-2 pts
