Old 01-24-2006, 10:02 AM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
Coolant in the #2 piston.
1994 Pontiac Grand AM 2.3L Quad 4. Engine started having bad idle and some white smoke coming out. I removed the spark plugs. Facing the front of the vehicle and looking at the engine and counting from the left to right, the #2 piston has some coolant in it. I have already removed the intake manifold, throttle body, fuel rail, fuel injectors and in the process to remove the exhaust manifold, etc. Am I correct to assume that the head gaskets needs replacement?
Thanks,
Slade901
Old 01-24-2006, 10:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Coolant in the #2 piston.
Yes you are correct. Make sure once you pull he head that you check both the block and the head for warpage. If the head is warped have it trued up at a machine shop before reinstalling it.
Old 01-24-2006, 10:42 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
if theirs coolant in the chamber/cylinder then I would say most likly your head gasket is blown out.
Has it leaked out any where else around the block, back or front?
1999 Grand Am SS 3.4 OHV
Old 01-24-2006, 10:21 PM
Slade901's Avatar
Banned
Currently, from where I can see, the leak is coming out of the spark plug #2
Old 01-25-2006, 12:59 AM
Riqand Riqand is offline
how much would a gasket prolly cost for a SOHC 4cylinder same block i think though not sure
