Old 01-24-2006, 06:40 AM
elric1970 elric1970 is offline
Unhappy escort won't start help!!!!
I cannot start my escort. When I turn the ignition nothing happens it's dead.
I tried the typical alternator test by turning everything on to see if the lights would dim on the dashboard but nothing happened.
I then tried to turn it on again because I forgot the wipers and it was dead.
I had someone boost me and it started up fine.
Is it the battery/starter/alternator????? And how do I fix it????
Old 01-24-2006, 08:10 AM
93 Freshcort 93 Freshcort is offline
Re: escort won't start help!!!!
when you jumped it, did the car continue to run? or did it die?
93 Escort 1.9L LX Hatchback - 285k miles
04 Explorer Sport Trac - 45K Miles
Funny & Offensive TShirts
WWW.AMERICASFUNNIESTTSHIRTS.COM
Free Resource's & Advertising @
WWW.LASTCORP.COM
Old 01-24-2006, 08:15 AM
after the jump it continued fine. I even started it up twice later on in the day.
Old 01-24-2006, 09:07 AM
My guess it's the battery. Check the connections to make sure you have a clean terminals. you may want to take the battery to an auto parts store and have them check it out. It's usually free. It may just be on it's way out. I would rule out the starter if it starts on it's own.
If the battery is good, it could be one of the many grounds gone bad.
WWW.LASTCORP.COM
Old 01-27-2006, 02:22 AM
UnexplodedCow UnexplodedCow is offline
Send a message via Yahoo to UnexplodedCow
The battery sounds like it's bad. Is it winter where you live? Mine did that. I had an el cheapo economy series. It was fine in the summer, but the day it got cold, my car was totally dead, no voltage at all. As soon as I stuck a charger on it for 30 minutes, and warmed the battery inside, the car ran fine.
