Old 06-17-2002, 04:29 PM
fatboyslim's Avatar
fatboyslim fatboyslim is offline
Question Paint Question
I am spraying Tamiya Acrylics through an airbrush and have always used water for thinning, after reading a few threads on here I now realise that is not the way to go.
So if using Tamiya thinner what ratio mix have you guys found is best?
See my models, click on HOMEPAGE below
Old 06-17-2002, 08:47 PM
Jay! Jay! is offline
Horizontally Opposed
I'm very imprecise; I mostly just eyeball it until it looks about right. For airbrushing, I usually end up using about 7:10 thinner to paint, I guess... Some guys on here will say that's too much thinner. It just takes a bit of practise to find how you like it.
Hierarchy of Subaru:
(Click to see mine!)
Old 06-17-2002, 09:34 PM
daggerlee's Avatar
I airbrush straight from the bottle, for metallics they are a bit coarse so I go for a 8:2 paint/thinner ratio (done on a 0.5 mm nozzle) at a low PSI, around 10-15. Ken Hartlett from Ken Hartlett's Motorcycle Modeling page has some old Tamiya paint manuals (from mid 80s or so) that state never to thin Tamiya acrylics more than 9:1 paint to thinner, but hey, who's counting.
Also, do yourself a favor and get the 250mL container of Tamiya thinner, it may be a bit expensive but it will last you a lifetime.
Dan
Old 06-18-2002, 05:47 AM
Bobj's Avatar
Bobj Bobj is offline
i use Tamiya arcrylics all the time with my airbrush and thin at 50/50 paint to thinner but 50/40 is pretty much spot on and allways use tamiya thinner as it has a spreader in it to make the paint spread out on the job.
Old 06-18-2002, 06:18 AM
xim-crow xim-crow is offline
Hi, you should have the same consistency as the milk !
Old 06-18-2002, 06:52 AM
Wishmaster's Avatar
Wishmaster Wishmaster is offline
***** Lurker
1 tiny question... if you mix paint with thinner in 50/40 ratio, where went the last 10%??
