Old 01-24-2006, 12:12 AM
muskilunge muskilunge is offline
wiring 2 amps
very noobie question here, but am at a loss. I have a mtx 2 channel amp along with an older kenwood single channel mono sub amp. I was trying to hook the rear speakers up to the 2 channel and am unsure of how it should be wired. with only 1 set of rca plugs coming out of the deck, and 2 amps, do you just get a splitter? same question for the remote wire, can you just jump it from one to the other? the deck is a pioneer 2600. Thanks in advance for any help.
Old 01-24-2006, 07:20 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: wiring 2 amps
you need to put the RCA's into a crossover, and then the output of the crossover into the two amps
Old 01-24-2006, 11:00 PM
Re: wiring 2 amps
thanks. will this then split the signal so that the rear speakers will work properly? the way it is now, I have just bass coming out of the rear speakers along with the sub. might just end up getting a pair of sibs for the 2 channle and a new 4 channel for the speakers I guess. just want this set up to work for now till funds build a tad.
thanks alot for the reply.
Old 01-26-2006, 10:53 AM
wojtas wojtas is offline
Re: wiring 2 amps
OK, u dont need an external crossover if u dont want it, just split the rca input, use a distribution block for the power wire, jump the remote wire and ground them seperately.
Old 01-27-2006, 12:15 AM
Re: wiring 2 amps
okay so an update. I have kinda updated my components a tad. I now have 2 12 subs and a 4300 e series jl 4 channel amp along with a mtx 2 channel amp. front 6.5 rear 6x9 and subs are all infinity.
my question would now be this.
I am currently running 4 guage wire from the battery to fuse block to distribution block. then 4 guage from distribution block to each amp. 150 amp fuse in main battery block and 50 in the distribution block. I am also using 4 guage ground wire. both amps are grounded separately. the remote wire from the head unit is run to the 2 channel and one wire runs out of the 2 channel over to the 4 channel. the rca plug has only one out put on the head unit. should I run to the 4 channel, then to the 2 channel or should the signal be split before running to either amp. also how would the wiring for the speakers and sub be layed out to run properly. the subs are 4 ohm and rated 50-300 rms. I am not sure what all that means as i am fairly uninformed when it comes to these systems. but I am trying to learn. so any and all suggestions are encouraged and appreciated. thanks for the help so far.
Old 01-27-2006, 10:22 AM
Re: wiring 2 amps
Split the signal b4 the amp, then run to each amp seperately. Connect the speakers off the amp normally. I would need to know the power ratings of the amps to tell which subs to hook to what amp, but dont go over the power handling of the subs.
Old 01-27-2006, 10:39 PM
Re: wiring 2 amps
thanks. I will have to look at them and get the specs for you.
Old 01-29-2006, 10:36 PM
Audio Guy
Re: wiring 2 amps
don't worry so much about amp ratings, just adjust the amp to the speaker
