Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-23-2006, 11:19 PM
captain1 captain1 is offline
Right front tire wear
Hi all, I have a '94 S-10 2WD that I get unusual tire wear on the passenger front tire around the edge of the tire. I changed the ball joints recently and was wondering if maybe this might be a worn Idler arm? Thanks,
Steve
Old 01-24-2006, 12:03 AM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: Right front tire wear
How bad is the truck out of alignment?
Old 01-24-2006, 12:21 AM
Had it aligned right after the ball joint replacement.
Old 01-24-2006, 08:13 AM
camohog1 camohog1 is offline
I have heard that some trucks will sit slightly lower on the passenger side for whatever reason. There is a stock kit that you can add that might help, butim not sure where u can get it.
Old 01-25-2006, 12:06 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
how long does the wear take? old tires or new? could be several things, pitman arm, ideler arm, toe off, or camber off, toe off will be noticed quickly while arms or camber will take time, does the vehical pull?
Old 01-27-2006, 10:02 AM
This is with new tires. The guy that done the alignment said that it was off pretty bad. I thought that I had done an alignment not long ago on it, though. There's a drop from the road onto my driveway when I pull into my house, and I hear like a deep "thud" on the right side when I turn in and drop down. I'm sure the alignment was just off on this thing. I'm gonna get a rotation and balance and keep You guys posted. Thanks for everybody's replies, Y'all are great!
Steve
Old 01-29-2006, 07:59 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
with a thud noise try checking the a arm bushings this would cause fast wear for sure
Old 02-08-2006, 11:58 PM
I think that this may be the arm bushings as You've described. When the truck bounces up and down I hear a squeaking coming from the rubber bushing and after further inspection, it has somewhat severe dry-rot. Are these a booger to change? From the looks, I thinking "yes". Thanks
Old 01-08-2009, 09:53 AM
tolaschkm tolaschkm is offline
check the idler arm and pitman arm.. and stearing shock...
Old 01-11-2009, 06:02 PM
old_master's Avatar
Advisor/Moderator
This thread has been inactive for 3 years, please check dates before posting in old threads.
Closed Thread
