Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-23-2006, 10:50 PM
94Caprice4.3L 94Caprice4.3L is offline
Starting problems
I have a 94 Caprice with the 4.3L V8 and It has trouble starting, If I Push the gas pedal to the floor it will eventually start, once its running it works pretty good, theres a little bit of stuttering but it doesn't die. I don't know what would make it not start. I replaced the fuel filter and spark plugs and i was thinking it might be some kind of sensor any ideas?
Old 01-23-2006, 10:57 PM
88capriceclassic 88capriceclassic is offline
Re: Starting problems
well, my 88 had very bad starting problems and im thinkin on myn its the choke stickin shut and not opening when it is supposed to.ive sprayed the shat outta it and still no luck but check ur choke flap after letting it warm up it should be quarter of the way open and when ran for a while hot it should be all the way open.
Old 01-24-2006, 12:42 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Car has sequential port injection - not a carb. No choke. To me it sounds like either an injection problem or a weak fuel pump. If you have access to one, put a pressure gauge on the service port on the injector feed rail and measure the pressure. It should be no less than 55 PSI.
Old 01-24-2006, 10:33 PM
oh my mistake, i dont know much about newer caprices. by reading wut i wrote,would u know how to fix this?can the choke be adjusted to not do that anymore??
Old 01-24-2006, 11:14 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
timing maybe?
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 01-24-2006, 11:21 PM
yea im kinda headin towards da same way wit dat too alot of people told me that might be one of the problems..ill get dat fixed
Old 02-05-2006, 01:44 PM
it was a theromastat senseor it was telling the car it was -19 below and it was feeding it gas
Old 02-05-2006, 02:19 PM
CD Smalley CD Smalley is offline
That will do it. Now since the car was being flooded with gas, I'd be on the look out for one or more of your convertors to fail....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-05-2006, 11:07 PM
silicon212's Avatar
Confoundingly Lucid
and the oxygen sensor. Replace that too - those fail faster than cats do.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
