Go Back   Automotive Forums Car Chat > Chrysler > Sebring | Sebring Coupe | Convertible
Old 01-23-2006, 11:05 PM
mitch712 mitch712 is offline
Unhappy Water Damage
99 Sebring convert first it sound as if a 5-gallon bucket of water was in the trunk after a car wash or rain. Finally it flooded the floor of my car.
Please help. All advice welcome
Old 01-25-2006, 10:27 PM
indyal indyal is offline
Re: Water Damage
are your drain holes clear if not the water will not drain right and will flood. If the drain holes are clear try putting someone in the trunk with a flashlight and run a garden hose aroung until they can see where the water is comeing from it could be a bad truck seal as well. good luck
Old 02-24-2006, 01:59 PM
Worcme Worcme is offline
Re: Water Damage
My 2001 LXi sedan has a cronic trunk leak, I had it into the dearler twice to replace the trunk seal and the vents. It didn't fix the problem. finally my dad just poked holes in the bottom of the trunk to let it drain. Everything on the passenger side of the trunk is always wet still but at least the water isn't standing anymore.
Old 12-04-2007, 11:50 AM
joecyrix joecyrix is offline
Re: Water Damage
I've got exactly the same issue with the same model car... Surely someone has fixed this... Sounds like a wave when you hit the gas or brake...
