overboring 3s-gte (question)
How to calculate WHP in relation to displacement? I have a table to approximate "targeted HP" vs. "injectors capacity"... but for even bigger injectors (1000cc +) how much overbore can be done to an iron motor like the 3s-gte so it can accomodate massive flows? what is the maximum capacity, and how to measure this? I kept reading about its "big potential" and I know its capable of delivering in the 800HP range.
Re: overboring 3s-gte (question)
If you want megga horsepower from a 3sgte engine, I wouldnt over bore it at all, you`ll only make it weaker...IIRC the max recommended bore increase is only about 2mm anyway so its hardly worth it, if you want a bigger displacement then get a stroker kit, but they arnt held in much regard either. you dont need to have bigger displacement to unleash the power available from a 3sgte, just a very well mapped engine, a BFO turbo ,huge injectors and deep pockets.
lol, that especially. |
what do you mean it'll make it weaker? will adding dipalcement ruin its compression? the way you put it, it sounds so easy to max out the motor's potential.
