Old 01-23-2006, 09:31 PM
Scaramanga Scaramanga is offline
92 3.1L Lumina .. random starts - BUT!?!? *pics*
After recently checking/replacing
Fuel pump - 4 years (30k miles)
Fuel Filter - 4 years (30k miles)
Fuel Pressure - OK (40 PSI)
Water pump - 3 years (20k miles)
ECM - NEW
CPS - NEW
EGR - Clean and removed A LOT of carbon/crap in all holes.
Plug and Plug wires - NEW
I still get some random no-starts.
When it wouldn't start I used this gadget to check for fire
Three times I have it connected after a nostart it showed NO fire -
but if I wait 10 secs it sparks like crazy and the motor starts, so I shut the motor off and try again 10-15 secs later after replacing the plug wire - and will start right up again and idle and drive fine.
Before it would have taken 30mins to 5 hours before starting again. (not testing for spark)
Does this make any sense? So far every time my car wouldn't start and I did check it for spark with the tester, it would aways start after 2nd turnover.
So what could it be? ICM ? Coil Packs?
Or a random freak of nature??
Old 01-23-2006, 09:50 PM
truc0011 truc0011 is offline
Re: 92 3.1L Lumina .. random starts - BUT!?!? *pics*
I had the same symtoms and it was a crank position sensor.....
Old 01-23-2006, 10:18 PM
I just replaced the crank position sensor last week....
Old 01-23-2006, 10:41 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I'd say Ignition control module or a bad coilpack.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 01-24-2006, 12:46 AM
Here she is
92 Euro ... 198,xxx miles
Just needs a little help
Old 01-25-2006, 07:57 AM
Carwhiz Carwhiz is offline
I agree with previous thread, you can check for resistence in the coil packs with an ohm meter and the ignition control module can be checked for free at autozone. On average the GM coils/module last 150K, so this is where I would start.
Old 01-27-2006, 08:06 PM
blitz9198 blitz9198 is offline
check your ignition coil packs, im pretty sure you can have them checked out at autozone for free....not sure where they are but I know there are 3 of them
